Error during build: Unable to compile MSI action install ass
[email protected]
Post by [email protected] »
Hello, I still get this error, in the last answer you suggested to edit the msi code, but that seems not possible, I have the developper version?
Please help, I am sending you the complete solution.
Thanks in advance.
Ruurd Eijzinga
[email protected]
Building Project: VapTex Eigenarenmodule
Output Folder: E:\Werk\VapTex\Windows Forms\EigenarenModule04\InstallAware\Release\UncompressedDeployment Type: Uncompressed Directory Layout
Code Signing: Disabled
Compression: Best
Compiler Variables: UAC=asInvoker,BUILDMODE=CD,"LANGUAGE=English","TITLE=VapTex Eigenarenmodule",TARGETDIR=$TARGETDIR$,IADIR=C:\PROGRA~2\INSTAL~3\INSTAL~2,PROJDIR=E:\Werk\VapTex\WINDOW~1\EIGENA~2\INSTAL~1,IAVER=13.00
Cleared output folder E:\Werk\VapTex\Windows Forms\EigenarenModule04\InstallAware\Release\UncompressedBuilt plug-in action Windows Installer
Built plug-in action .NET Framework
Built plug-in action (Un)Install MSI Setup
Built plug-in action File Bag
Copied file E:\Werk\VapTex\Windows Forms\EigenarenModule04\bin\Release\eigenarenmodule.exe
Copied assembly E:\Werk\VapTex\Libraries\VapTexLib1108\bin\Release\VapTexLib1108.dll
Error during build: Unable to compile MSI action install assembly
EigenarenModule04.zip
(1.29 MiB) Downloaded 378 times
Re: Error during build: Unable to compile MSI action install
Dear Ruurd,
Please be patient, I will be back to you as soon as possible.
