hi,
i m using IA 2012 studio version and wants to remove branding from dialogs i read your thread given below
http://www.installaware.com/forums/view ... f=2&t=6769
as you mention
"When you use an InstallAware dialog theme, you will see a label that is placed on the top left corner of each dialog. This label will contain the text "$TITLE$ Setup - InstallAware Wizard""
So I'm not seeing the behavior you describe above where the caption is "$TITLE$ - InstallAware Wizard", it's just "$TITLE"
and also i didn't find this Variable "MYAHLOGO" .
how and where do i set this variable to remove branding from all dialogs
Branding Removal
Re: Branding Removal
In your dialogs caption you have just the $TITLE$ string, because "InstallAware Wizard" it is automatically added at runtime by the IA engine.
If you want to replace this behaviour, simply set the "MYAHLOGO" variable as TRUE at the very beginning of your main script.
Set Variable MYAHLOGO to TRUE
Please note that the above feature is available starting from InstallAware 11.
