How can I disbale any uninstallation using the MSICode inside InstallAware.
So, there should not be created any entry at AllUsers/ApplicationData and ControllPanel/Software
Complete Disable Unistall
Re: Complete Disable Unistall
Dear user,
if I haven't missed anything, you want just to perfom a sequence of actions on target system, without performing a complete installation package.
am I right?
If true, just do what you need without using Apply Install in your script (setting NATIVE ENGINE variable to TRUE if Purple Commands are used).
Of course doing this your modifications can't be unistalled.
am I right?
