tofutim
Post by tofutim »
Hi, I was able to swap out the logo for the startup screen (InstallAware is preparing...) by adding my own installaware.png to the Creatives. However, for about half a second, the original InstallAware icon still shows in the second dialog. It is a bit jarring. Is there any way I can fix this?
Re: Delayed swap of installaware.png
Actually it is this the behaviour and can't be modified.
Unfortunately I am not able to tell you more about.
tofutim
Post by tofutim »
In case anyone goes down this path, I tried modifying dependent.exe and internal.exe as well as the output setup.exe with Resource Hacker to no avail. It's hidden deep somewhere. I think it is a clue that the window is glassified unlike the password protection or the "verifying contents" dialog.
tofutim
Post by tofutim »
I found an exe in the Dialogs for my Theme that looks internally like dependent.exe and internal.exe. Changing the icon in this does not help either.
As with my last reply ... Actually this is the behaviour and can't be modified.
Paul Guthrie
Post by Paul Guthrie »
It would be good if this behaviour could be fixed. It is really not a professional look. Any chance of fixing this in an upcoming software update?
Paul G
Dear Paul,
Unfortunately this behaviour actcually can't be modified.
