Combobox validation
Ton_B
Combobox validation
Post by Ton_B »
I've created a specific Dialog.
On this dialog there is a combobox.
Users can begin typing inside te combobox, and, even type a value that's not in the list.
I'm wondering how I can prevent this from happening.
I want the user to be able to only select one of the available options.
How can I do this?
Ton Blokhuizen
Tooling Engineer
BMA BV - Netherlands
http://www.bma-mosos.nl[/i]
Re: Combobox validation
Dear Ton,
please set "csDropDownList" as style property for the ComboBox in dialog editor.
Ton_B
Post by Ton_B »
Fantastic, works like a charm :D
Is there by any change a manual or help available for using the User Interface Editor?
I could not find any help regarding to the available controls and its properties.
Thanx.
Ton
Ton Blokhuizen
Tooling Engineer
:D :D
Ton_B
Post by Ton_B »
Hello Fransesco,
I'm glad that you're happy :
:D :D
But, do you have an answer on this question ?:
Ton Blokhuizen
Tooling Engineer
Dear Ton,
... ops, I really missed your question!
Unfortunately it is not available a documentation from IA about Dialog controls and properties.
If you want for these you can refer to Delphi/C++ Builder controls and properties documentation and eventually to MSDN documentation.
Actually is available "Dialog Editor" topic in IA help documetation.
