I am trying to include an unsigned COM Interop component and register it with the /codebase option.
I can register this OK manually (obviously I get a warning about unsigned assemblies)
Microsoft (R) .NET Framework Assembly Registration Utility 2.0.50727.3053
Copyright (C) Microsoft Corporation 1998-2004. All rights reserved.
RegAsm : warning RA0000 : Registering an unsigned assembly with /codebase can ca
use your assembly to interfere with other applications that may be installed on
the same computer. The /codebase switch is intended to be used only with signed
assemblies. Please give your assembly a strong name and re-register it.
Types registered successfullyI have got this to work OK using InstallShield but I would prefer to use InstallAWARE if at all possible.
Thank you in advance.
