Printing code no word wrap
Ton_B
Post by Ton_B »
Sometimes I want to print my code.
But the code does not word-wrap.
I found a topic, (from 2005) but can't find if this problem is solved?
http://www.installaware.com/forum/viewt ... ?f=2&t=688
Does someone have a trick on how te get all of my code on a piece of paper without words falling off the edge? :D
The printer option "Fit on paper" of my printer, has no effect :(
Ton Blokhuizen
Tooling Engineer
BMA BV - Netherlands
http://www.bma-mosos.nl[/i]
Re: Printing code no word wrap
Dear Ton,
I am very sorry, but actually seems that the only possible workaround is to print the txt file version of a script.
The txt version file should be available in the project folder for any script file you are using.
Ton_B
Post by Ton_B »
Ok,
I will take a look at that.
Maybe i can paste in into Notepad++ which supports color styling.
Ton Blokhuizen
Tooling Engineer
Dear Ton,
I really do not know if color styling will be keeped .... but using "Copy as Text" of course will possible.
