Change InstallAware logo?
Adam
Postby Adam » Tue Jul 10, 2012 5:35 am
Hi
I'm struggling to change the InstallAware logo on a Single exe where it says "InstallAware is preparing the InstallAware Wizard which will install this application", immediately after it verifies the installer (where the logo works).
Screenshot:
Does it need to be done in a different place than Add-Remove?
Cheers
Adam
Re: Change InstallAware logo?
Postby FrancescoT » Tue Jul 10, 2012 9:51 am
Dear Adam,
just add a PNG format image file (32x32) as "InstallAware.png" to the Creatives page of your project.
tofutim
Postby tofutim » Fri Jul 19, 2013 9:29 pm
I find that this technique doesn't seem to work any more in InstallAware 16. Could I be missing something or has this changed?
Postby FrancescoT » Mon Jul 22, 2013 11:41 am
... let me check.
Postby FrancescoT » Thu Jul 25, 2013 4:17 am
Dear Tofutim,
just to inform you that the issue you found has been fixed with the last IA update currently available (IA 16.07).
It should be just enough to re-generate the license file to have the updated installed, if upgrading from IA 16.06.
Users browsing this forum: No registered users and 120 guests
