Stop and start service
bernaert
Postby bernaert » Mon May 15, 2006 2:13 am
I need to stop a service before the installation of the .net framework 2.0 and restart it after the installation.
If I would stop the service from the command prompt, I could do it with the following command line in the windows system32 directory: net.exe STOP SWEEPSRV.SYS
I've tried this in my script using the run program, as program I've specified $WINSYSDIR$\\net.exe and as command line parameters I've specified 'STOP SWEEPSRV.SYS'
It does not work. Is there something wrong with the parameters?
I've tried without quotes and with quotes or do both have to be quoted?
Thx for the help,
Bernaert Dominique.
Postby MichaelNesmith » Mon May 15, 2006 2:54 am
Is the variable WINSYSDIR initialized at the point you are making your call?
Users browsing this forum: No registered users and 34 guests
