Can I build projects using a command line tool?
for example using:
> miabuild.exe -single "C:\\My Projects Folder\\project1\\MyProject.mia"
or something else?
Build project with command line
Yes, of course! The correct command line parameters are described in the help, or if you run the tool without any parameters from the command line.
Great !
But I have an error when I launch it.
My command lines looks like:
that gives:
Program returned code : 3
Do you have an idea ?
>miabuild.exe "Path to project file\\MyProject.mia"
that gives:
Command Line Build Utility
ERROR: '' is not a valid integer value
You build the MPR file, not the MIA file.
Re: Build project with command line
Hi
I cannot pass variables as parameters during build.
I have following code in script:
And this is my command line:
This does not pass version with value 10. I have tried for variable watch on both variables CMDLINE and COMMANDLINE but both variables are blank. And the VERSION variable is set to the value I have given in wizard. Please let me know where I have done the mistake.
Set Variable COMMANDLINE to $CMDLINE$
if Variable COMMANDLINE Contains (Ignore Case) VERSION
Set Variable VERSION to $VERSION$
End
miabuild.exe "Demo1.mpr" VERSION=10
first of all I suggest to you to have a look to InstallAware Docs regarding "Building from the Command Line" (as usual press F1 in IA IDE).
By the way, You're trying to build from the command line passing a script variable but the command line build options accepts COMPILER VARIABLE.
For example:
passing: miabuild.exe "MyTest.mpr" MYCOMPILERVAR=1234
In your script should have:
[compiler if Variable MYCOMPILERVAR Equals 1234]
MessageBox: debug, Test Compiler Variable
[compiler end]
For example:
[compiler end]
Users browsing this forum: No registered users and 16 guests
