Variables are not being translated.
norbertjurkiewicz
Post by norbertjurkiewicz »
Hi everyone,
After purchasing the product and setting up new projects they don't work. I had no issues with the demo versions.
So far the $PROGRAMFILES$ and now $SHORTCUTFILESALL$ variables are not being translated during installation. Please advise as I cannot , shouldn't have to 8) , crate workarounds for all of these.
Thank you.
Re: Variables are not being translated.
what do you exactly mean with?
Can you post the steps you used to create the project?
tzachk
Post by tzachk »
Just a thought,
Did you make sure that you use $PROGRAMFILES$ after it was initialized?
If you opened the dialog before you initialized the parameter, you'll get $PROGRAMFILES$ instead of the actual path to Program Files.
Regards,
T.
norbertjurkiewicz
I manually initialized it to make it work. I though these were supposed to be initialized internally and it it would be always available.
tzachk
Post by tzachk »
The definition appears in region define setup globals (at least on my blank project)
If you open the dialog after this region, you'll get what you looked for.
Regards,
T.
