Program size in Add/Remove programs
kishorkk23
Post by kishorkk23 »
I am not able to see any program size in the Add/Remove program. Do we need to set/add any attribute?
Re: Program size in Add/Remove programs
Dear user,
This is determined internally by MSI, but I know that it is often miscalculates (exaggerating sizes) or missed as you found.
If you want is possible to correct the displayed value using Write Registry.
Please have a look at the following link:
http://www.ottawahomenetwork.com/Knowle ... Correctly/
kishorkk23
Thanks for the information :D
:D
