Platform Ready Test doesn't find UpgradeCode
Daniel Öberg
Post by Daniel Öberg »
When running Microsoft Platform Ready Test Tool - Version 3.5.0.0 for Windows Server 2008 R2 the tool can not find the UpgradeCode and the test is failing.
Test case/Verification: TC1_2 - Is the Package Identity correctly configured?
Property Table must contain:
Manufacturer, ProductCode, ProductLanguage, ProductName, ProductVersion (major and minor)
Upgrade Table must contain:
UpgradeCode, VersionMin, VersionMax
MSI Package must contain an Upgrade Table.
At least one UpgradeCode must match an UpgradeCode in the Property Table.
VersionMin and VersionMax must be fixed if they are both 'null'.
Property Table:
PROPERTY: UpgradeCode
VALUE: null or empty
PROPERTY: Manufacturer
VALUE: InstallAware Software Corporation
PROPERTY: ProductCode
VALUE: {FA01A538-B54E-4D3D-9A26-6CCB49E294AE}
PROPERTY: ProductLanguage
VALUE: 1033
PROPERTY: ProductName
VALUE: XXX
PROPERTY: ProductVersion
VALUE: 1.0
Upgrade Table does not exist.
Running the same text on setup.exe instead works as it should. (Yes, of course I can see the upgrade code under project details in Installaware)
Seems like the msi packages are not created as Microsoft wants them. Any ideas?
BR,
Daniel
Re: Platform Ready Test doesn't find UpgradeCode
Dear Daniel,
All of the required fields are populated there, please see my attached screenshots.
This is what I find when I do an uncompressed build on a Basic Setup and open the resulting MSI file.
upgrade code in property table.PNG (60.41 KiB) Viewed 10532 times
upgrade table.PNG (53.33 KiB) Viewed 10532 times
The same happens, if you run a compressed build and inspect the MSI placed in the temporary direct of your target system.
Daniel Öberg
Agree it looks good in your screenshot, but if I do the same I lack the table shown in your second image.
I can see the UpgradeCode, but I don't see the table for it.
What I do is generate a compressed exe and then run the GP tool on it to get the msi. Then the msi seem to lack this information.
Daniel
Dear Daniel,
as I said with my last reply;
When you create a compressed build, this wraps internally the MSI file effectively used by the installation.
ncgjka
Post by ncgjka »
Hi! I am probably stupid, but from your above discussion, what do you do about it? How do you get the Upgrade table to appear and thus make the MSI pass the Microsoft Platform Ready Test Tool. I can only see that you have established that the table is missing when creating compressed builds (to .exe). My question is, how do you include the Upgrade Table to such a build?
Or do you mean that that is not possible, and that i should buid an Uncompressed Directory Layout build to use in the Microsoft Platform Ready Test Tool test??
//Jens
Dear James,
a compressed setup EXE can't expose any MSI property, because it's an EXE file and not an MSI file.
Said that, you should use the un-compressed build layout.
