Equivalent script for Check In-use File from Wise
aziaaddini
Hi: Is there an IA equivalent script for Check In-use File? We call that in Wise and would like to be able to do something similar with IA. Thanks.
Re: Equivalent script for Check In-use File from Wise
unfortunately, It is not available a ready to use command for that.
Anyway, you could use a call to CreateFile WIN API to get if the file is used.
Please have a look at the following topic:
http://www.installaware.com/forum/viewt ... f=2&t=8772
Alternatively, also the following could help you.
http://www.installaware.com/forum/viewt ... f=2&t=5814
