A newbe question.
Jerzy
A newbe question.
Postby Jerzy » Tue Aug 28, 2012 2:14 pm
I open the IA project created in Visual Studio but i can't find any files I selected in VS to be copied into $targetdir$ or into GAC, the Files/$targetdir$ and Assemlies lists are empty. Where can i find these files to know what will be installed (and where). This is important because i need include outputs from many projects/solutions in one IA project and want to avoid files duplication. Additionaly it is nice to see what happens during installation.
Regrads
Jerzy
Re: A newbe question.
Postby FrancescoT » Wed Aug 29, 2012 7:38 am
Dear Jerzy,
are you using the InstallAware Add in with Visual Studio?
If true, your files are installed by a predefined script called "InstallAutogen", added automatically with InstallAware project creation ( ... select "Create a setup project" from "InstallAware" Visual Studio menu).
This script is executed by your setup package by the following code that you should have with your main script:
- Include Script: InstallAutogen
Open the script "InstallAutogen" in IA MSI view and you should have the code that effectively installs your files ( ... you can use the "Launch InstallAware" command from "InstallAware" Visual Studio menu).
Return to “Non-Technical”
Users browsing this forum: No registered users and 7 guests
