WISE InstallBuilder import?
ChrisMcElyea
Postby ChrisMcElyea » Thu Aug 30, 2012 8:13 pm
Can you import an existing WISE installation setup or do you have to rebuild it? Also, can InstallAware consume Merge Modules?
Re: WISE InstallBuilder import?
Postby FrancescoT » Fri Aug 31, 2012 8:11 am
Dear user,
With InstallAware you can convert Wise Logic (The Wise script WSE ext) or the Wise Setup created using Wise language script(WSE ext files).
Choose "Add Modules to Project" in Merge Modules node in the InstallAware project tree view, to select the Merge Modules you wish to add.
In addition, you could use the InstallAware Database Import Wizard.
the Database Import Wizard opens a Windows Installer setup (MSI file) or merge module (MSM file) database. It inspects the contents of the database, extracts and/or copies files from inside the database and/or source media, and then emits a ready-to-build InstallAware setup, complete with a customizable script. The Database Import Wizard provides a very easy way to import existing Windows Installer databases into InstallAware.
Return to “Non-Technical”
Users browsing this forum: No registered users and 7 guests
