Runtime error in setup script:
jcastillo
Post by jcastillo »
Source File: MainScript
LineNumber: 1401
Access violation at address 74C315DA in module 'version.dll'. Read of address 00000004
Re: Runtime error in setup script:
just with the information you posted it is really difficult to help you.
Of course, exist something at LineNumber: 1401 of your Mainscript causing the issue ... but if you don't supply any other exhaustive information will be really hard to find out what happens.
b4all
Post by b4all »
I'm getting the same error while installing Delphi XE3.
We cross check with people, who installed Delphi XE3 successfully, for the version.dll sizes and versions but they are the same.
May be some dependency dll that linked inside version.dll is causing this issue. Or another installed application effecting this.
System:
Windows 7 Ultimate x64 (up to date).
Also I can give extra information if needed.
I'm very sorry but for this you must contact Embarcadero.
InstallAware is just the tool used to deploy the package and only who developed it may know exactly what happens there.
