Error with build single exe setup
ajacques
Post by ajacques »
HI,
I had no problem with the trial version of Install Aware when I was testing with it, since purchasing a licensed version I can no longer build a single exe install.
I get the following error:
Error during build: Cannot open file "C:\Program Files (x86)\InstallAware\InstallAware 2012\{40D0CDA0-F0E2-469C-B4C7-4BBC41920ADB}". The process cannot access the file because it is being used by another process
This is getting very frustrating as I need to get my product to customers...
Andrew
Re: Error with build single exe setup
Dear Andrew,
I am sorry, but it is not clear to me which InstallAware version are you using?
With the other post you report IA ver. 8 and with this one seems you are using NX.
Please use just one topic and don't mix the same question with different topics, otherwise will be very hard to help you.
Can you clarify?
