I just purchased virtualization 5 and am attempting to virtualize my app using a Windows 7 computer. To isolate the changes, I created an offline project.
I ran the PackageAware program to capture the setup changes, and the resulting .miv file was 1.75 MB. (encompasing 415 files, 173 folders, 235Mb) There appears to be some memory or size limits in the package editor, as it frequently crashes when managing files or registry settings.
When attempting to right-click or delete HKLM\Software\Microsoft\Windows NT\CurrentVersion\Winlogin folder, the program crashed:
Problem signature:
Problem Event Name: BEX
Application Name: ivpb.exe
Application Version: 3.2.2.4
Application Timestamp: 505f232b
Fault Module Name: ivpb.exe
Fault Module Version: 3.2.2.4
Fault Module Timestamp: 505f232b
Exception Offset: 00044dfd
Exception Code: c000000d
Exception Data: 00000000
OS Version: 6.1.7600.2.0.0.256.48
Locale ID: 1033
Additional Information 1: 19ae
Additional Information 2: 19aec45c127d4a585f72059580c5b200
Additional Information 3: 2199
Additional Information 4: 21992ea894e76499bcc0150697ea4358
I used an XML editor to manually edit the .miv project to remove the keys that crashed the editor. When I attempted to build the EXE, the editor crashed with the following error:
Locale ID: 1033
Additional Information 1: baad
Additional Information 2: baadf6d5b9868aa04bd1eea50e581f4f
Additional Information 3: c04f
Additional Information 4: c04f529f1d1aee87f6135e1606e3aea9
I will be happy to send you the project and and project files for you to analyze.
Jeff
Virtualization 5 crashes on larger projects
JeffryPaul
Artem A. Razin
Re: Virtualization 5 crashes on larger projects
Could you please upload the files somewhere and send me a link to support (at) boxedapp.com ? I will check it.
Thank you in advance!
