I am trying to use 'Control Service' to 'start on install' the MSDTC service that is part of the OS. Using it in always results in a Permission Denied message. However, I can successfully start/stop the service by issuing this in a command window: sc start MSDTC
I have the install elevate to administrator and still I cannot start the service using your 'Control Service' directive. If I add the 'sc start MSDTC' to the run program section, all is good and it works.
What do I need to do to ?? Is there a bug with Control Service ?? Is there a permission I need to grant during the install ??
Help.
Control Service permission issues
Re: Control Service permission issues
unfortunately that service requires additional permissions that actually are not possible to specify using Control Service IA command.
http://blogs.msdn.com/b/distributedserv ... tarts.aspx
The only opportunity that you have to complete it successfully is using "Run Program" command.
I used the following and works fine.
~InstallAware Clipboard Data~
~Run Program~
~{67EB3509-AC27-43D7-8BEA-B21317C12BB6}~
~sc~
~TRUE~
~start MSDTC~
~TRUE~
