i got a stupid problem which i cannot solve. But i think the solution is easier as i think ...
- i copy some files via "unzip 7z" to local temp (C:\Temp\xyz\)
- i then want to copy a file out of C:\Temp\xyz to another local target, lets say it is P:\xxx- BUT during doing this, i want the file to be renamed
The Copy/Move local files command windows seems to me as this can be done.
The source file in my example is called A_300.exe, and the target name should be A.exe (without the version number)
This is my msiCode:
Copy Local Files $sourcefolder$\A_*.exe to $targetfolder$\A.exe
(Apply Install (get result into variable success))
