Details of the Get System Settings please
matthewj
Post by matthewj »
Could you add more details of the Get System Settings script command to the help please? It seems to be more complicated than "true or false" now, and could perhaps do with a table to explain the responses. In particular, the "Logged on User Privilige Level" is unlikely to be true or false, but experimentation probably isn't too useful or fast.
Many thanks,
Matthew
sinan
Post by sinan »
You are correct! We forgot to update this function while revising the documentation.
The possible return values for your indicated parameter are:
ADMIN
POWER
USER
GUEST
ERROR
Please let me know if any of the other parameters are unclear. I apologize for the inconvenience.
matthewj
Post by matthewj »
Many thanks.
Matthew
matthewj
Post by matthewj »
Long time since I asked about this, but I've now had two Swiss users having problems with my code. Could you divulge the secret of how you are determining whether someone is a power user or not? The users all say they are local administrators, but it is possible they are domain administrators. In any case, I don't let them install and other apps aren't a problem to them.
I'm wondering if it is some issue with key user groups or GUIDs that you are checking for that might be different on foreign systems.
Thanks, Matthew
My code is as follows:
~InstallAWARE Clipboard Data~
~End~
~{6D66938F-180C-4877-BB1F-B9E226097836}~
~Terminate Install~
~{8C77C01D-FCCC-4FB3-9933-E847A3CFFD45}~
~MessageBox~
~{8ABCDAA2-9239-4C58-8CAC-7B421A95ED10}~
~$TITLE$ Setup Error~
~This product requires Power User or Administrator Priviledges (current rights are $CHECKUSER$).$NEWLINE$$NEWLINE$Please right-click on the setup executable to use the "Run As" option (in Windows 2000 hold Shift to see the option).$NEWLINE$$NEWLINE$Setup cannot continue.~
~3~
~1~
~If~
~{FE5A704A-8524-4007-A7B3-010AEA53379C}~
~BX_SHOW_ADMIN~
~0~
~1~
~FALSE~
~End~
~{475141D2-F535-43FE-A280-0556FFB891BF}~
~End~
~{BE5C02A9-5FF6-485B-B06B-04056D9EE88C}~
~Set Variable~
~{B601B9C4-902B-43CA-9C28-1CFA70023B74}~
~BX_ALLOW_ALL_USERS~
~TRUE~
~If~
~{534951B8-0E46-4EDB-9E41-3B70DF895188}~
~ISNT~
~0~
~TRUE~
~FALSE~
~Else~
~{24F953F7-C937-49F4-BE7D-D6F4B0DD4833}~
~End~
~{915951C7-33CF-4CA6-851C-47F861258A57}~
~Set Variable~
~{5D4EA44C-7269-4857-B200-BC5EFB60042E}~
~BX_SHOW_ADMIN~
~0~
~If~
~{D63BCE68-E547-45CF-8F9B-4391C1F97B63}~
~CHECKUSER~
~0~
~POWER~
~FALSE~
~MessageBox~
~{C52C7BFC-8C2D-49EA-AF3B-9658FC38EB8A}~
~User power = $CHECKSYSTEM$~
~0~
~1~
~Get System Settings~
~{EF5995E5-8F21-49FB-805B-04F314123ABA}~
~CHECKUSER~
~63~
~Set Variable~
~{1CFD4BF0-7DC8-4D76-949F-2E622D9B07F5}~
~BX_SHOW_ADMIN~
~1~
~If~
~{5BCF4703-2D78-4557-A9F7-8ED049DE6B5F}~
~CHECKSYSTEM~
~0~
~TRUE~
~TRUE~
~{841BA2A3-DB15-4899-A87F-02332B9CB2D5}~
~CHECKSYSTEM~
~0~
~Set Variable~
~{471F8BFE-889A-4961-8DE9-3528F88BC4A1}~
~CHECKUSER~
~Unknown~
~Set Variable~
~{07584F40-D32B-4283-BF7B-43E549EAA040}~
~BX_SHOW_ADMIN~
~0~
sinan
Post by sinan »
What version of InstallAware are you running? Some builds earlier than sp1.passion_update2_rtm.050927 had problems detecting domain admins when they were members of very large domains.
matthewj
Post by matthewj »
Ahah - that may be relevant. I did the original build with an older version I think. The latest one I've done using a, err, newer one :wink: so it may be that the problem will just go away.
I'll refresh the main site with the latest one and see if it recurrs.
Matthew
