Problem editing shared strings
alibaba
Post by alibaba »
Hi, if I try to edit the shared strings I get the error message:
Error
No translation project found in directory 'C:\Program Files\InstallAware\InstallAware NX\trans\'...
OK
See attached pictures. What can I do? I have integrated the Translation Manager Pro.
the IA "trans" folder
the error message after klick on shared strings
Re: Problem editing shared strings
Dear Alibaba,
Are you using or have you installed any other translator tool application?
alibaba
Post by alibaba »
Yes, as I said I have integrated the Translation Manager Pro.
I have asked this question in the related forum, too and there is a answer:
http://casic.dyndns.org/Forum/Topic1349.aspx
Thanks for posting it.
