Disable Tabs in PageControl
mikKummerfeld
Post by mikKummerfeld »
Hey Guys,
how can I disable a tab in your pagecontrol tab? I tried different ways, but not successful.
Thanks in advance
Heiko
MIK
Kind regards
Heiko Kummerfeld
MIK GmbH
Head of quality assurance
technical consultant
Re: Disable Tabs in PageControl
Dear Heiko,
I'm very sorry but I really don't understand what is the tab that you want to disable in InstallAware IDE.
mikKummerfeld
I have 4 components and on one dialog a pagecontrol with a tab for each component with a few options for shortcuts
When a user selects only 2 components, I want to change 2 tabs to enable =false (grey, not clickable)
pagecontrol with tabs
Kind regards
Heiko Kummerfeld
MIK GmbH
Dear Heiko,
unfortunately it is not possible to disable the page tab selection.
Alternatively you could force via "Dialog Behavior rules" the Enable property setting for a specific page using a variable .
mikKummerfeld
i tried
IF (c_tools.State = cbUnchecked) THEN tabOlap.Enabled := False;
c_tools is my checkbox (Checked if component was selected, UnChecked if not)
This does not work, tab is still enabled=true
Kind regards
Heiko Kummerfeld
MIK GmbH
Dear Heiko,
you should try setting to FALSE the Enable property for that specific page under the PageControl.
Doing this all controls on the page will be disabled.
mikKummerfeld
tabOlap is the name of my page and I tried to set this to enable=false but it doesnt work
Kind regards
Heiko Kummerfeld
MIK GmbH
Dear Heiko,
Please use the attached project that demostrates how handle the Page Enable property and how to enable / disable controls as well.
PageControl.rar
(1.54 MiB) Downloaded 393 times
mikKummerfeld
Thank you.
Yeah I tried to set every control within the page to enable=false (WORKS),
but I cant set one rule for all controls (making them GREY LOOKING)
Kind regards
Heiko Kummerfeld
MIK GmbH
Dear Heiko,
It works in that way because the property disables the page fuctionality and not the controls.
