I need to overwrite files with an older version. I change the option in native engine setting but it doesn't work. In installshield express we have the possibility to in inform wich version number can be overwrite. How can i do the same with installaware express.
Best regards
Overwrite files
Re: Overwrite files
Dear sytel,
the only oppurtunity that you actually have with IA Express edition, it is to create a project based over the NATIVE SETUP IA template.
In this way you should be able to control files overwrite with the pedefined variables NATIVE_OVERWRITE & NATIVE_OVERWRITE_OLDER.
Please refer to IA documentation for more detailed informations.
