IF with OR
mikKummerfeld
IF with OR
Post by mikKummerfeld »
Hello Guys,
I want to check the target installation folder for windows illegal characters ?, :, *, etc
How can I check this with "OR"?
IF $TARGETDIR$ contains ? OR : OR *
messagebox "Not allowed..:"
goto label destination
END
I dont know how to do that
Heiko
Kind regards
Heiko Kummerfeld
MIK GmbH
Head of quality assurance
technical consultant
Re: IF with OR
Dear Heiko,
You can only use nested IF for that.
mikKummerfeld
Re: IF with OR
Nested is only AND ???
Kind regards
Heiko Kummerfeld
MIK GmbH
bokkie
Re: IF with OR
Post by bokkie »
Heiko,
What about having a Dotnet exe (file bag) and passing in the string you want to validate? The exe could validate your string using a regex which is a standard namespace in Dotnet?
Re: IF with OR
Dear Heiko,
via command script no other possibilities are available ... but the Bokkie's suggestion, can be of course another opputunity to validate a path via external code.
REgards
