I've got some troubles with custom dialogs.
I've modified the progress dialog in order to have smallest and basic form.
* First of the problems I meet is the Form Caption.
The property Caption of my form is set to $TITLE$ but when I install my soft the caption is "- InstallAware Wizard" ???
I don't understand why, but when I uninstall my soft the form caption is correct.
* The second problem I have is the position of the form. I want it to be in top left corner. I set top property to 10, the left property to 10 and finally the Position property to poDesigned.
When (un)installing the form is screen centered ???!!!
* Can I hide the first package validation form?
Thanks for your help
Troubles with custom dialogs
Re: Troubles with custom dialogs
Search the forum there is another issue open for this question..
crustyzz wrote:* The second problem I have is the position of the form. I want it to be in top left corner. I set top property to 10, the left property to 10 and finally the Position property to poDesigned.
I can't help you on this..
crustyzz wrote:* Can I hide the first package validation form?
Which is the validation form?
Panagiotis Kefalidis
Software Design Team Lead
Gizm0 wrote:Which is the validation form?
This one. See attached file.
<a href="files/0602200637/capture_06022006_100340.jpg">capture_06022006_100340.jpg
Oh, no this cannot be changed, it can only be localized, as you did.. It's an internal InstallAWARE dialog which cannot be edited.
But you can still use the powerful dialog designer on the rest of them, to create your own unique dialogs for you setup.
Sorry, it is not possible to set the items you requested.
Gizm0 wrote:But you can still use the powerful dialog designer on the rest of them, to create your own unique dialogs for you setup.
It's done
MichaelNesmith wrote:Sorry, it is not possible to set the items you requested.
Sorry, it is not supported.
Both, I'm afraid.
Users browsing this forum: No registered users and 47 guests
