IIS Application Extension Mapping?
jaxmeier
Post by jaxmeier »
All,
Do any of the versions of InstallAware support Application Extension Mapping in IIS? I have several extensions that need to be mapped in my installation.
jax
Gizm0
Post by Gizm0 »
At the moment no, but as far as i know, the development team is working on such a feature for the next version.
Panagiotis Kefalidis
Software Design Team Lead
jaxmeier
RE: IIS Application Extension Mapping?
Post by jaxmeier »
Gizm0 wrote:At the moment no, but as far as i know, the development team is working on such a feature for the next version.
1) Any idea on a time frame? Our need is immediate, of course...
2) Any suggestions on a workaround? If I can do it using a vbscript, is that possible using InstallAware?
jax
Gizm0
Re: RE: IIS Application Extension Mapping?
Post by Gizm0 »
jax
1) Timeframe, i don't know at the moment
2) Of course you can do it on VBScript.
You can create your script, add it as a support file to InstallAWARE and execute it later.
You will use Run Program to run the $WINSYSDIR$\\wscript.exe $SUPPORTDIR$\\the_script.vbs as parameter to execute it and Wait for Completion
Also, you can create your own dll/exe on your favorite programming language and execute it from InstallAWARE.
