custom avi format?
Nick
custom avi format?
Postby Nick » Mon Jun 05, 2006 3:38 pm
I'm trying to use the animate control and use an avi file we've made.
I added the avi as a support file but when I try to enter our avi as the file for the animate control I get: Invalid Property value.
Any ideas why? Are only certain avi formats supported?
jimo
Postby jimo » Tue Jun 06, 2006 9:51 am
Did you remember to change the CommonAVI property to aviNone?
Then change the FileName property?
Jim Oswell
Greenway Health, LLC
http://greenwaymedical.com
Nick
Postby Nick » Tue Jun 06, 2006 11:32 am
yes. As a test, if I use the gray.avi (which I also have as a support file) as the filename it accepts it fine. Which is leading me to believe that there is something with the format that the control doesn't like.
jimo
Postby jimo » Tue Jun 06, 2006 12:17 pm
Hmmm, don't know where to go from here I have 2 other AVI's that I use in my packages that are not distributed with IA .
Jim Oswell
Nick
Postby Nick » Tue Jun 06, 2006 12:27 pm
Thanks Jim,
The avi we're having problems with has properties of:
Frame rate: 7 frames/sec
Data rate: 54kbps
Video sample size: 16 bit
Video compression: MS-CRAM
We were able to change the first two but unfortunately don't have any software here to make avi files in different formats for the last 2.
Are you aware of a utility that can easily make avi files, preferrably freeware?
jimo
Postby jimo » Tue Jun 06, 2006 1:39 pm
You may want to try
[utl]http://www.videohelp.com/convert[/url]
Jim Oswell
Postby MichaelNesmith » Tue Jun 06, 2006 3:09 pm
Also try copying the AVI file to this folder before testing and/or setting the property:
C:\\Program Files\\InstallAware\\InstallAware 6\\interop\\templates
(It might be a differentf folder on your system)
Nick
Postby Nick » Wed Jun 07, 2006 2:44 pm
unfortunately copying the AVI to the directory you suggest Michaell didn't work. Still getting Invalid Property Value.
I'll try playing with the AVI file settings when I get a chance to see if that fixes it.
Postby MichaelNesmith » Wed Jun 07, 2006 5:38 pm
You are just typing the AVI name, and no path, right?
I guess Jim's direction is the way to go on this one.
Nick
Postby Nick » Wed Jun 07, 2006 5:43 pm
Yeah, just the name. I tried the absolute path once but that didn't work..
Users browsing this forum: No registered users and 52 guests
