I know this sounds odd, but I need to create an installer that will install some files on the machine, or uninstall, depending on a switch I give the installer.
I know that part is easy.. however, the installer should not put an entry into the Add/Remove programs applet in Windows. Is there any way to have InstallAware not insert those entries?
No Entry in Add/Remove Programs
That was going to be my "fallback" way of doing it. Works for me, I was just looking for a cleaner way.
Thanks!
Thanks!
jimo wrote:Its all in the registry.
Depending on All Users or Just Me install, look under HKLM or HKCU.
SOFTWARE\\Microsoft\\Windows\\CurrentVersion\\$TITLE$.
You can delete this key - after Apply Install.
Users browsing this forum: No registered users and 21 guests
