DOWNLOAD FILE
Senthil
DOWNLOAD FILE
Postby Senthil » Fri Nov 23, 2012 5:39 am
As I am getting an error message when i am downloading file from the localhost. i am using IIS7. Please help me in this regard.
This is my MSI Code....
Set Variable RESULT to
Set Variable TARGETLOC to D:\IA\TEST2
Download File http://localhost/MYDAPP/SAMPLE.TXT into $TARGETLOC$ (get result into variable RESULT)
MessageBox: D- RESULT, $RESULT$
if Variable RESULT Equals SUCCESS
MessageBox: RESULT=, SUCCESS
else
MessageBox: RESULT: =, FAILED
Thanks in advance
Senthil
Re: DOWNLOAD FILE
Postby FrancescoT » Fri Nov 23, 2012 8:47 am
Dear Senthil,
if you type " http://localhost/MYDAPP/SAMPLE.TXT" in your browser are you able to download the file?
Senthil
Re: DOWNLOAD FILE
Postby Senthil » Mon Nov 26, 2012 12:26 am
Yes, getting reply in the browser when i am giving this URL " http://localhost/MYDAPP/SAMPLE.TXT"
Re: DOWNLOAD FILE
Postby FrancescoT » Mon Nov 26, 2012 9:58 am
Dear Senthil,
Honestly, I just tried to download a file over my network and works fine.
In order to to do an extra verification, have you tried to replace your file URL with something else available over internet?
mikKummerfeld
Re: DOWNLOAD FILE
Postby mikKummerfeld » Wed Dec 05, 2012 4:29 am
Hello guys,
I have the following problem while downloading files from our server. In the top of the script it works perfectly,
but when I want to download the files within my script (where the installfiles commands are) it fails.
Do you have an idea?
[DEFINE WEB MEDIA MIK.arjuna]
   Get Component MIK.arjuna Selection State into Variable SELECTED
     Download File http://www.mik-support.de/setups/arjuna/files/MikArjuna2501.7z into $TARGETDIRLOC$\MikArjuna2501.7z (get result into variable downloadstate)
     Extract .... into TARGETDIR
Kind regards
Heiko Kummerfeld
MIK GmbH
Head of quality assurance
technical consultant
Re: DOWNLOAD FILE
Postby FrancescoT » Wed Dec 05, 2012 10:09 am
Dear Heiko,
Without having your complete project it is not easy to give you a correct answer ... but this could be caused because your Downolad command it is located within a WEB MEDIA BLOCK definition.
Please try to verify what happens moving the Download command just before that WEB MEDIA BLOCK and anyway, outside of any other existing WEB MEDIA BLOCK.
mikKummerfeld
Re: DOWNLOAD FILE
Postby mikKummerfeld » Fri Dec 07, 2012 8:30 am
I can confirm that it does not work within web media block, but outside of that.
Kind regards
Heiko Kummerfeld
MIK GmbH
Re: DOWNLOAD FILE
Postby FrancescoT » Fri Dec 07, 2012 9:19 am
Happy you solved!
mikKummerfeld
Re: DOWNLOAD FILE
Postby mikKummerfeld » Fri Jan 25, 2013 11:20 am
try this one Senthil:
~InstallAware Clipboard Data~
~MessageBox~
~{DEB2084F-583F-433E-84DE-D12E54275377}~
~newresult~
~$newresult$~
~0~
~1~
~Call DLL Function~
~{2360D2D1-F71C-4912-803F-8A6C8815543F}~
~Urlmon.dll,URLDownloadToFileA,long,newresult,long,0,"pointer to string",http://www.domain.de/file.txt,"pointer to string",$TARGETDIR$,long,0,long,0,$~
~mIDEFunc.dll\mEXEFunc.dll~
~Set Variable~
~{4EF1EE3D-BCAA-4A2A-9F8A-4DB45CC3838F}~
~newresult$MYAH$MYAH$FALSE~
Kind regards
Heiko Kummerfeld
MIK GmbH
SteveDude
Re: DOWNLOAD FILE
Postby SteveDude » Mon May 21, 2018 7:23 am
Glad you have it solved too. I'll mention this and it may save a headache or two later. depending on the server,.7ZIP is not always defined as a MIME type, so when I've had problems with it that's one of the first things check.
Users browsing this forum: No registered users and 45 guests
