MSI - show list of files
pwall
Post by pwall »
Hi.
If I use ORCA to look at an MSI, one of the properties is 'Files'. However, this property is always empty.
Is there an option in InsatllAware to propagate this property ? I've seen other msi's (visual studio) that do fill this property, I'm hoping that InstallAware can as well.
Discalimer: I did search via google, the on-line help and this forum but didn't find anything pertaining to this question.
Re: MSI - show list of files
I suppose you are not using the correct file.
If your package is compressed, you should look at the MSI copied to the local temporary directory*.
Otherwise, produce an uncompressed build and point to the msi created under the folder release\uncompressed.
*Note, when a compressed package is executed its contenent is expanded to a local temp directory.
pwall
Post by pwall »
Hi Francesco. Thnanks for the response.
Here is a screen-shot using the 7zip.msi as an example. I've edited the msi with ORCA, and selected 'Files'. it lists all the files that are in the msi that get installed.
When I create our msi's using InstallAware, and I use ORCA to edit and select 'Files', the list of files in the msi that get installed is empty. The msi works fine, everything installs and as is good.
I'm curious to see if I can get InstallAware to provide this information. It would be a useful feature for us.
Here is an example of one of the msi's that I create.....
Thanks!
Patrick Wall
Dear Patrick,
as I previously said, you are inspecting the wrong file.
The msi file generated by InstallAware is a compressed container that embeds internally the effective msi file.
When this packaged is executed, its contenents is expanded to a local temp directory, which contains the correct msi file that you have to use.
The uncompressed build reflect exactly the same contents structure, that you have when a compressed build it is temporary expanded to a local directory.
pwall
Post by pwall »
Ok, I understand now.
I build a new msi, uncompressed, which didn't make any difference.
HOwever, I executed the installed and 'found' the imbedded msi, and it has all that info.
Thanks!
Patrick.
