Minimum Supported OS Check on IA NX
Sheri_Steeves
Post by Sheri_Steeves »
I need to block my installer on all operating systems before Windows 7, meaning I only want to run the installer on Windows 7, Windows Server 2008, Windows Server 2008 R2, Windows 8 and Windows Server 2012.
If a use the Application Requirements to target Windows 7 ( as this is supposed to be a minimum check) my installer fails in Windows Server 2008. If I set the minimum check to be Windows Server 2008, then the installer fails in Windows 7.
I ended up using Get Exact OS and checking for all OS's from 95 - Windows 2003 and setting a variable WRONG_OS to TRUE if I detected any of these and terminating the installation if WRONG_OS is TRUE.
Is there a better way to do this? Why is the Windows 7 system check blocking the Windows Server 2008?
Sheri
Re: Minimum Supported OS Check on IA NX
Dear Sheri,
this is not an error.
You found this behaviour because WIN 2008 indentifier (WIN32_WINNT macros declared with WIN SDK) is not greater than the one used to identify Win 7.
For examples these constants are defined as follow with WIN SDK heders:
#define _WIN32_WINNT_NT4 0x0400
#define _WIN32_WINNT_WIN2K 0x0500
#define _WIN32_WINNT_WINXP 0x0501
#define _WIN32_WINNT_WS03 0x0502
#define _WIN32_WINNT_WIN6 0x0600
#define _WIN32_WINNT_VISTA 0x0600
#define _WIN32_WINNT_WS08 0x0600
#define _WIN32_WINNT_LONGHORN 0x0600
#define _WIN32_WINNT_WIN7 0x0601
For more informations please refer to "Using the Windows Headers (Windows)" with MSDN documentation.
Sheri_Steeves
Francesco,
Of course... as a programmer I should have realized that!
Sheri
