Shortcut in Install Removes Existing Pinned Shortcut
Sheri_Steeves
Post by Sheri_Steeves »
I have a shortcut to the Windows services applet in my install (services.msc).
What I am finding is that if I already have the Services applet pinned to my Windows 7 taskbar ( Control Panel - System and Security - Administrative Tools, right-click Services shortcut and select Pin to Taskbar), running my installer will remove the pinned shortcut.
How do I install a short cut in my Start Menu folder to the Services applet without removing the user-customized pinned shortcut.
Sheri
Re: Shortcut in Install Removes Existing Pinned Shortcut
Dear Sheri,
I'm supposing this happen when you unistall - reinstall your application with an update.
Unfortunately, doesn't exist a ready to use command for that.
I suppose that the only way you have to achieve this, it is to first obtain if the application is pinned and then, re-pin it again via shortcut command.
Sadly, I believe that the only method to obtain the actual pinned status parameter is through WIN API, for more info please refer to:
http://msdn.microsoft.com/en-us/library ... S.85).aspx
Most of the data are stored in the registry under: "HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\"
.. but it's not easily editable.
tofutim
Post by tofutim »
Hi we just switched to Native and had a user complain about this happening. They had a number of pinned start menu items and the installer wiped them all out of the start menu. Can you advise? (We had to switch to the Native Engine because a user had a French Start Menu and we were getting an illegal character issue.)
Dear Tofutim,
during package removal, by design and even with Windows installer, any component used by the application is removed (including shortcuts).
did you read my reply to your other post?
