Mysql and InstallAware
bigtimery3k
Post by bigtimery3k »
I am trying to build a setup that is mysql dependent. I'd like to install the mysql server, start it and run a script. Any ideas r welcome.
Please read this whitepaper:
You may use the File Bag command to add the native MySQL setup files to your setup, and the Run Program command to run the MySQL native installer (if its an MSI setup, use (Un)Install MSI Setup instead).
This way you can customize the application runtimes view and add a check-box to install MySQL. If you don't mind sharing, please post your new application runtime here for everybody to share :D
