I want to disable a radio button from within mia script
I want to disable and enable a radio button from within one of my scripts. I'm having difficulty even getting started. I'm sure such a basic function is easy I just can't find an example.
Re: I want to disable a radio button from within mia script
Dear keefie,
Please use as starting point the sample available with the following post;
http://www.installaware.com/forum/viewt ... f=2&t=9340
It demostrates various examples on how to handle controls functionality.
The sample demostrates also how to disable a standard button using a script variable but the same approach can be used to control radio buttons.
