Hello Guys,
I only found a way to extract 7z-archives, but I need to extract downloaded .zip-files during installation.
How can I do that the best way ?
Extract ZIP Files
Extract ZIP Files
Kind regards
Heiko Kummerfeld
MIK GmbH
Head of quality assurance
technical consultant
Heiko Kummerfeld
MIK GmbH
Re: Extract ZIP Files
Deir Heiko,
for ZIP archives you should follow which suggested by the following topic;
http://www.installaware.com/forum/viewtopic.php?f=3&t=4389
Unfortunately, it is not available a ready to use command with InstallAware for this format.
Users browsing this forum: No registered users and 93 guests
