Executing command
bigtimery3k
Executing command
Post by bigtimery3k »
Can i use the run program command to run a command i would normally run from the windows command prompt?
jimo
Post by jimo »
yes
Jim Oswell
Greenway Health, LLC
http://greenwaymedical.com
bigtimery3k
I am executing the command but the command is giving an error. Is there a way i can see what the error is?
jimo
Post by jimo »
FIrst try setting the current working directory using the call dll command calling SetCurrentDirectoryA in kernel32.dll.
If it still fails write out a batch file with a wait run the batch file from your installer and read the screen.
Jim Oswell
bigtimery3k
Can i pass variables from the installer to the batch file
jimo
Post by jimo »
You can write the batch file on the fly using the Write to Text File command.
Jim Oswell
bigtimery3k
thanks. trying it out.
