PROGRAM DATA files
alphonse777
PROGRAM DATA files
Post by alphonse777 »
Hello all,
I have files that I copy into Program data...
My software needs read and WRITE to them.
I need to change their rights so that ALL USERS can write to them.
I use to do it with installshield express, but with RAD Studio Edition I cannot fond how to do it ...
I would like to avoid to make a dedicated software for this task....
Thanks a lot.
Al.
alphonse777
Re: PROGRAM DATA files
- No one knows ? -
you could use the "Set Access Control" command for that if with IA RAD Studio Edition you have access to MSI scripting feature.
Otherwise, you should create and call a dedicated DLL or EXE for that.
alphonse777
Thanks FrancescoT !
I do not have access to the "MSI code" tab ... this is a delphi embedded version
I juste have this
but no way to define any rights here...
I'm sorry but what you want to can't be achieved using Install Files command.
The only possibility that you have with your edition, it is to call an external component (ex; an Exe).
