Hello
I tried to install an application made with InstallAware 11 on windows 8
But the OSLEVEL is recognized as UNKNOWN
is this a limitation of IA 11? Does IA 11 not work with windows 8?
regards
Hans
Installaware 11 Windows 8
Re: Installaware 11 Windows 8
Dear Hans,
this happens because at time when IA 11 was distributed WIN 8 was not available.
Alternatively, you could use a call to "GetVersion" WIN API via "CALL DLL FUNCTION" to obtain the OS version number.
This function has been superseded by GetVersionEx ... but it should stil work.
Hello Francesco,
thanks a lot for help.
<<Alternatively, you could use a call to "GetVersion" WIN API via "CALL DLL FUNCTION" to obtain the OS version number.>>
Can you give me a small example code? I do not know which function do you mean?
thanks a lot
regards
Hans
thanks a lot
regards
Hans
Dear Hans,
please try this;
For more info about the function, please refer to the MSDN documentation at;
http://msdn.microsoft.com/en-us/library ... s.85).aspx
please try this;
~InstallAware Clipboard Data~
~MessageBox~
~{2BCA2E97-9414-4038-B1E0-2D5E61C95441}~
~Debug~
~OSVERSION = $OSVERSION$~
~0~
~1~
~Call DLL Function~
~{ED3C6D60-9897-4868-8601-6D15FA826E20}~
~Kernel32.dll,GetVersion,"double word",OSVERSION,$~
~mIDEFunc.dll\mEXEFunc.dll~
~Set Variable~
~{2D1976EA-1F7F-49AD-8C02-47FB21E2E32B}~
~OSVERSION$MYAH$MYAH$FALSE~
