Patch works only once 2
redbyron
Postby redbyron » Fri Jan 04, 2013 8:43 am
i have the same issue as described on the http://www.installaware.com/forum/viewtopic.php?p=11554 post,
but i cannot see the msp file in add/remove programs in order to remove the patch.
Also if i re-run the msp it prompts that removal of patch is not allowed.
The OS is win 7 64bit.
The only thing that we can do in order to repair the installation, is remove and reinstall....
Please advice
Regards,
Michael
redbyron
Re: Patch works only once 2
Postby redbyron » Fri Jan 04, 2013 8:52 am
I just checked the setups in the rar file that exist on the following post http://www.installaware.com/forum/viewtopic.php?f=2&t=9343 ,
and it has exactly the same behavior...
Regards,
Michael
Postby FrancescoT » Mon Jan 07, 2013 5:00 am
Dear Michael,
patch installation doesn't add any entry to add remove program.
redbyron
Postby redbyron » Mon Jan 07, 2013 6:26 am
Ok, patch installation does not add an entry to the Updates History in add remove programs...
But what about the main issue?
The repair mode of the installer, removes the files installed by the patch and does not put the original files back unless you remove and reinstall....
Regards,
Michael
redbyron
Postby redbyron » Thu Jan 10, 2013 4:03 am
Any news regarding this issue?
It is a very common senario for an end-user to repair an installation...
Regards,
Michael
Postby FrancescoT » Thu Jan 10, 2013 8:49 am
Dear Micheal,
I am still verifying it, that's the reason why I did not reply to your post.
I'm not totally sure, but I suspect this is the MSI engine standard behaviour due the modification of the file table references applied by a patch.
I'll be back as soon as I have enough information.
Users browsing this forum: No registered users and 112 guests
