Good Day,
Without any changes to the program (vs 2010 on Windows 7 64bit, vb.net) I am suddenly getting a message, Error: Include file "setupnet351" does not exist. )And of course, this is the final compile before I am schedule to update the program)
Thanks for you help
V Whitehead
Install failure
Re: Install failure
unfortunately, by the only information you post it is not easy to try to help you.
For what you said, probably it can be caused by some modifications occured to your system (... I'm just supposing it).
What InstallAware version are you using?
Anyway, the "setupnet351" should be an IA runtime script;
can you verify if the file really exist under "Runtime" sub-directory of your InstallAware installation folder?
