IE proxy script used but downloading file fails
mikKummerfeld
Post by mikKummerfeld »
Hello Guys,
one of our customers uses a proxy server with the automatic configuration file in internet explorer settings.
Internet connection is available but downloading file fails every time :(
What can I do ? Please help
Kind regards
Heiko Kummerfeld
MIK GmbH
Head of quality assurance
technical consultant
Re: IE proxy script used but downloading file fails
Dear Heiko,
have you checked if it works entering directly in IE your download URL?
Are you sure that doesn't exist any restriction on client permissions?
mikKummerfeld
Same URL works in IE without problems...
Kind regards
Heiko Kummerfeld
MIK GmbH
mikKummerfeld
no help?
ok but anyway....I use now the urlmon.dll and function URLDownloadToFileA and it works without problem at this customer.
Your download-file function does not work.
But I really would like to use your function. Can you fix that problem ?
Kind regards
Heiko Kummerfeld
MIK GmbH
