Problems "RUNASADMIN" in $DESKTOPDIR$
Rulan
Post by Rulan »
creating a desktop-button to "run as admin" do not work... :(
(The same defining under $shortcutfolder$: everything works fine...)
Have a look (IA15 + WIn7 64-bit):
Rulan
Re: Problems "RUNASADMIN" in $DESKTOPDIR$
Post by Rulan »
Any ideas?/workarounds?
Or do we something wrong?
regards
Rulan
Post by Rulan »
No response? :(
Is it a bug??? :o
CAN ANYONE CONFIRM the problem? :o
WORKAROUND???? :o
Dear Rulan,
please have a look at the link below;
http://www.installaware.com/forum/viewt ... n+as+admin
Rulan
Post by Rulan »
Dear Francesco,
thanks for the reply...
But ???? what do you mean???? with your link????? :(
please have a look at at my pictures above, you can see that there is no flag set in the advanced options!
And please remember, as I mentioned, it only did not work in "$desktopdir$"...
It seems to be a bug????
regards
Let me verify it.
Rulan
Post by Rulan »
Hello Francesco,
can you give me status of my problem?
regards
Dear Rulan,
we verified what you reported and this is not caused by a bug with the desktop shortcut creation, but instead by the value used by DESKTOPDIR variable.
In other words, (as we experimented and I suppose even in your case) to have the command working correctly (mainly when using MSI engine with your package generation) you must verify that the passed desktop folder parameter with the shortcut command, points to a path value that reflects the "PER MACHINE or PER USER" installation context used by your setup package at runtime.
More pratically, you should have with your main script the following code lines placed immediately after the setup interview.
if Variable ALLUSERS Equals TRUE
  Get Common Folder Location System->Desktop Directory into DESKTOPDIR
else
  Get Folder Location System->Desktop Directory into DESKTOPDIR
* where the first call to "Common Folder Location" obtains the path for all users and the second one just for current user.
NOTE
I suggest you to update your IA installation to the new 15.32 version, where fixes has been introduced with "Get Common Folder Location" command.
