i try to build a installer with IA 15 (test version) for our company
my problem is , that we have an old .exe setup file that we use to ignore by executing all the Error Messagebox manually (click on the button)
so when i want o run the installer now with this msicode
~InstallAware Clipboard Data~
~Install Files~
~{DBA23DE6-52AC-4A2C-A9AC-0495E136F7D2}~
~C:\Test_Installer\1st TCAppInstall\setup.exe~
~FALSE|~
~$TARGETDIR_X86$~
i got an error and i think its because the error meaasagebox which we have in our old .exe stp file
how can i ignore the massagebox in our old .exe programmtly from InstallAware??
how to ignore an error Messagebox during the installation
Re: how to ignore an error Messagebox during the installatio
Hi i really need an answer please, because i should know if we need to buy the InstallAware Product or not !?
Dear Hassan,
I'm not quite sure if I follow your question.
Do you want to capture the returned value from your old installer in InstallAware?
or
Do you want to skip from InstallAware a MessageBox that it is part of your old Installer?
or
