Share folder on network
christ23
Post by christ23 »
Hi folks,
in one install scenario we have to create a folder on a network share - this works. But we also need to share this created folder, this works not.
This is my code in a test project:
Set Variable folder to \\tt-fs01\DATA\B\test
Create Folder $folder$
Share Folder \\tt-fs01\DATA\B\test as "testshare"
The "Share folder" command has no return value so i cannot see why, but the share is not shared.
When i use "C:\Temp\test123" as folder, everything works.
The installer is NOT run on the tt-fs01! The installer runs on another machine, ist this the problem? But why then can i enter "remote machine" in the Share-command?
Am i missing something?
Re: Share folder on network
the command to work correctly requires the real physical path of the remote path to share.
This is the same requirement if you try to manually share a remote folder using the Shared Folders snap-in "fsmgmt.msc".
Of course to work correctly, the command also requires that the user who executed the setup package (locally) has the required privileges to complete the command.
