I have discovered that the variable SFXPATH is not working as desired.
I have a single-exe build that is startet from c:\tmp\foo
$SFXPATH$ is c:\tmp
I would suggest that it holds the value c:\tmp\foo
I can reproduce it with more than one project and I am not modifiing the variable in script.
Edit: for a network folder it is working well...
$SFXPATH$ not working anymore
Re: $SFXPATH$ not working anymore
Dear Alibaba,
just to confirm that the issue has been logged to our fixes list.
Currently, I can't say about the availability of the fix.
can you tell me since when it is not working? I need this function and have do downgrade my IA...
Dear Alibaba,
I suggest you to use the CMDLINE pre-defined variable at this time and manually parsing it.
I'm sure, you will be able to extract the path you need.
Dear Alibaba,
just to inform you that the issue you reported has been fixed with our new InstallAware update 15.32.
Users browsing this forum: No registered users and 136 guests
