Nalpeiron Service
mwilner
Nalpeiron Service
Post by mwilner »
I am using Nalpeiron licensing service and had an add on installer for IA 10 that apparently isn't working with the latest release of IA15.
Can you help me getting the service installed in IA 15?
Manfred Wilner
Re: Nalpeiron Service
Dear Manfred,
Personally I have no knowledge about "Nalpeiron licensing service" and if you try to describe more specifically your issue, probably I'll be able to help you.
Anyway, if this service works as any other standard Win service application, I believe that should be not required any particular task.
mwilner
Post by mwilner »
Thank you Francesco, I think we figured it out.
It was just a matter of placing the service applications in the right directory.
Manfred Wilner
I'm happy you solved! :D
Nalpeiron
Post by Nalpeiron »
I figured I would pop in here, I understand the topic is older. In the future, if there are issues with http://nalpeiron.com, please drop us a support request at: http://www.nalpeiron.com/support.html. Our team is eager to help and will work with you to find a solution.
Cheers,
Nalpeiron
