[SOLVED] Total Required Space & Feature Independent Files
How do you get total required space to reflect the space consumed by feature-independent files? I tried using Get Component Space without an argument, but it displays 0 as well when I select the Compact setup type.
Re: Total Required Space & Feature Independent Files
please have a look at the attached project that demostrates "Get Component Space" command.
The sample includes as well the builded setup package ready to run.
- Components space.rar
- (1.89 MiB) Downloaded 384 times
Well it wasn't my use of Get Component Space that was the problem. It was my use of Get Component State. I did something like this...
When I looked back at the Files page in the Designer I saw that my files were associated with the Documentation feature. Is there anyway to avoid this other than ordering the setup to install the feature-independent items first?
Get Component Documentation Selection State into Variable SELECTED
Install Files C:\PRODUCT\disc 1\common\docs\*.* to $ALLAPPDATA$$COMMONDIR$\docs, include subfolders
Comment: Install/Re-Install Product
Install Files C:\PRODUCT\disc 1\target\bin\*.* to $TARGETDIR$\bin, include subfolders
If I haven't missed your question ...
From InstallAware Design View you can remove those files from a feature and then you can add them again under the correct feature.
Alternatively, you can move the Install Files commands to place them under the correct feature (within the appropriate IF statement).
Users browsing this forum: No registered users and 111 guests
