Problem running an IA 10 installation from web in Windows 8
brunderj
Post by brunderj »
Are there any issues that you know of with an installation built in IA 10 installing properly on a Windows 8 operating system when it's run from directly from the website?
I had a client report a problem when he tried to run the installation program from the website, rather than downloading it to his computer first. The error said it couldn't create a folder in the AppData folder: C:\Users\dmaharaj\AppData\Local\Temp\miaC9A5.tmp\
Regards,
John
PS - It worked for him when it he downloaded it and ran it from the hard drive.
Re: Problem running an IA 10 installation from web in Window
honestly, we are not informed of a similar issue.
I have also just tried to do the same using my test environment and worked fine.
I have used the last InstallAware version to build the package, but for what I know the error that you seem to have, it is not related with the IA version you used.
Probably, it could be caused by security settings enabled with that system.
brunderj
Post by brunderj »
Francesco,
Thanks for the info. I suspected as much. He was able to install it just fine by donwloading the setup first.
Cheers, John
